Hi
So as it turns out I was stupid enough to buy a car with a leaking steering system, now that we cleared that,
This is what the rear part of the steering pump looks like after I wiped it:
the steering gear also shows some signs of leaks, but it appears they are not recent, or are they?
and a view on the lower joint from beneath:
view from the top on the lower joint and you can see a little leak in the area of the pressure sensor:
I bought the car 11 months ago and haven't added any steering fluid in that time:
Is it a common problem?
What should I do in this case?
