MOT
My mot is due at the end of september, and it says on my mot form i can have it done at the end of this month, if i do this and the car fails, will i still be able to drive it as i need a car to get to work while its being fixed?
If you have the MOT done early and it fails, your old MOT certificate will still be valid.
However, if your MOT passes, your New MOT will only last 1 year from the Pass Date, so you're going to loose out on 1.5 months worth of MOT... Why not just wait until end of Sept unless you're extremely sceptical about it passing at that time...
Mo.
because if you take it on the earliest date e.g 1 month before you will get a 13 month mot.
im just not sure how it worked if the car failed
You won't get a 13 month MOT. If it passes it'll be valid from this month for 12 months. If it fails you can still drive it until the end of Sept.
If it fails and you don't get the problems fixed by end of Sept you can't drive it unless you book it in for a MOT and drive straight there, if you get pulled over then you have to prove that it was booked in for MOT and you were going straight there.
Aye if it fails then It's still covered under the previous MOT which is why you're always better to take it early.
You can take it from 30days before right up to your previous MOT date and have 12 months added onto the date that way you don't loose out.
Take it from September 1st :)
well my mot said 27th august is the earliest i can take it in to preserve whats left on it, but i was thinking of taking it 2 weeks or so time.
nope i thought you can get 13months mot.
if your mot is due on the 1st of sept and you take it on the within the 30 days prior and it passes as long as you have your older motcert the new one will be issued a year on from the old one ie 1st sept 2009
well thats always happened in my case as my mot had been due 5th of nov since ive owned the car and i always take it a week or two before incase there is any problems. Thankfully there hasnt been any so it has passed the week or two before but as i always take my current mot cert they just add a year on to that one.
I'm with Nismo Billy on this - sure I've had 12.5 months' MoT in the past. And also was under the impression that once it had failed, regardless of how much time was left, it was illegal to drive it unless yer on yer way to a garage to get the problem fixed or get the re-MoT...
yup you can get 13 mnth mot, but mind if the tester finds a danerous fault then he can void the old mot cert, but it has to be pretty bad for him to do that.
dont think there is any dangerous faults or any at all with my car actually
just trying to find info so i can put things into place be it im carless for a few days...
I do this all the time because I'm paranoid about cars failing and not being able to drive them.
As people have said, and you pointed out from your test certificate - as long as you don't take it in earlier than 30 days before your MOT expires, the new MOT will be issued as if you had taken it in on the day it expired - i.e. a 13 month MOT. If the car fails (fingers crossed it doesn't) your previous MOT is still valid until it actually runs out...so basically you get a month(ish) to fix whatever is wrong with the car.
However, if the MOT fail is something critical and the police pull you over and spot it - valid MOT or not, they can still impound your car.
Only if he is driving about as normal without a MOT. If it fails, he gets it repaired and then he books it in for re-test and get's pulled on the way there and proves its booked in for a MOT and he was going straight there he'll be alright.
Unless he has shopping in back seat or is like 50miles in wrong direction from the garage.
Yeah true...it has to be on the system though, and yeah...you have to be on your way there. My mate tried to pull this little trick and it failed badly...ended up paying through the nose to recover it from the pound on a tow truck lol served him right really!
