My MOT is not due untill Sept but was wondering if i went for a MOT now and it failed would i need 2 get it fixed there and then or could i wait untill its due in Sept?
Don't forget however, even if you are unaware of any non roadworthy conditions your car is in, if you have an accident or get pulled and the car checked over, ignorance is no excuse, you can still be prosecuted.
Dan
The MOT is not a certificate of road worthiness except at the time of the test.
The driver is responsible for making sure the car is roadworthy at all times. Okay you probably wont get done if one of your lights has just gone off (although technically you can), but say youve been driving with bald tyres, they didnt just happen, same with defective brakes, generally you are expected to get them checked sufficiently so that you dont sufddenly find youre metal to metal on pads or shoes.
But original point stands, if your car fails MOT at anytime it can be then proven that you knew about it if you drive afterwards. Also dont forget if your car fails the MOT miserably, in other words it is dangerous to drive, forget about the "allowed procedure" to drive a vehicle home after a test, if you get caught you can be done for it.
