The bulb is probably burned.
Remove the radio trim > remove the 4 bolt holding the screen in > behind the screen there will be 5-8 bulb holder, remove that, and you can access the bulb itself, It helps if you also unplug the screen so you have more movement.
I believe the bulb was the 1.2W bulb, if not, probably the W5W.
