my car
bmc air-needes
check out the last mod i did and tell me what do you think.
which is the best way to dunk air?
before/after
they both look like good setups. In fact I'm copying one of those. I think the best thing to do, is to go to the track and test both setups. Which ever gives you a better 1/4 mile time is the best setup. :lol:
kia tat> Thanx man,most of the mods are made by me! But still got a ga14de engine :O
shifty> good thinking man,but no trax here in athens its a bit of along way/pay distance to do that. Thats the sht we are talking mainly and make as run on the streets like craze! :mad:
blast
Never thot that a weber fuel pressure regulator and a de-cat removement makes such a diference on tha road!
My mechanic reached that fuel pressure at 2.8 bar :D and with the help of the headers my car make a big flame/smoke blast as i leave the pedal at 5000 rpm continuing with a noisy rrrrrrooooooaaaaaaaaaarrrrr sound.
Am i ok ? Or leading to destruction.
So the decat is worth it then?
Got a price for full system yesterday, £210 cat back and £280 de-cat, was wondering if the extra £70 would be worth it!
shudnt cause any damage ma8 as its only unburnt fuel and u got nowt in ur zaust that u can bust. part from the cats wich u have removed so its all good :D :D
Ye definately worth it on the 1.6. I had a decat on my sunny SR and i noticed a difference not so much on the GTI however.
Well designed cat ;)
I want a cheeky flamer for my motor!!!!! :D
why don't you get your cat back and then get a decat pipe from Shade on NPOC...he sells them for like £50...absolutely mint quality tig welded stainless steel jobbies mate...saver yerself a couple of quid... :)
*edit* - are the cats the same on prims and meras!? :confused:
if not then scrap what i just said... :D
Yep, they same on heaps of Nissans. Even up to R34 I think. The cat's diameter at the flange is about 3" so it can handle pretty big bore piping.
Well then...there you go...already saved your self £20 and for £50 you get gaskets and stainless steel bolts as well so they won't rust if you want to change it over for mot's etc....;)
see i'm good to you...:D
Need to look at this as Im having it done at exhaustsuk and might add a flamer for personal pleasure! ;) (kinda like them)
Supposedly the decat is a on off job so not sure how it works, guessing just bolts like you say!
Should be getting a discount with them too so looking for at least 10% off that price so might not be worth it in the end.
Will have to see, cheers for the tip anyway
Rear spoiler
check out the Peugeot 307 rear spoiler
Had to cut the edges first to fit that on my car
cos the back of the 307 is more round than mine ( messy staff )
liked the focus sting also but didint fit at all!
So here it is..
hey i like that, good to see summin different on a mera, would have to see it from the rear too tho. U got any pix?
Yep, have 2 rear pix man just for you!
I'd seen the work u've done flamera guy its awesome!
here you go..
