not a clue yet.. I've got a b16a1 (vtec yo) engine in the garage that I may build a b20 out of. But I fancy going crazy RB stylee. For now im going to work on the shell then see about fabricating some mounts for a chunky rear diff and independent suspension. Fun fun fun. TO THE SCRAPPY!
The block isn't. Trust me.. it'll fit I've hade the tape measure out. will need mods to the transmision tunnel(or complete lack of in this case) rad will need relocating and the use of an electricaly powered fan will be required. It's just on the drawing board at the mo. doing plenty of research. not set in stone.
your dead right on the handling. the problem is that its a short and wide car. I was thinking along the lines of pushing the block as far back as possible. minor mods to the fire wall if required. position the seats right back with a longer steering column. fuel tank, rads and relay looms in the boot(all been done before). I think its a go'er.
Oor I could go back to planA. b20 block b18(itr) head and rocker 4wd box out of a honda shuttle.
Im definatly goining to get another one as they're amazing cars to drive (little go-karts). My advice to anyone on a budget to NEVER buy Goodyear EagleF1s for the front and leave the back with low tread. Amazing wet weather grip on the front and no grip on the back = bent rear wheel as above.
Can you not fix that mate??
Same happened to my old micra and I fixed it by replacing the whole rear axle assembly.
It looks a bit close to that lamp post also!
the damage was worse than it looks. rear assembly chasis mount was twisted and almost torn off. It would need jigging and I dont have the equipment for that. I fancy a SiR next. Learning to speak Jap to cut out the middle man. Also banned from driving due to enjoying vtec in wales so I've got a while to get another car on the road.
