N/S knocking... Again...
A while ago i posted a thread about a knocking noise coming from the n/s rear wheel. Since then it seems to have gotten worse and is now knocking constantly when my car is moving.
I'm gonna have a go at stripping and cleaning the drum brake and see if this makes a difference, but has anyone got any ideas what it could be?
Jack the wheel up and try to wobble the wheel, there should only be a tiny bit of free play in the wheel. If its a lot of wobble, it could be the nut with the split pin is too loose or the bearing isn't right.
Update: There is no evident wobble i could feel so i'm guessing the bearing is fine, however i did notice that the brake shoes are touching the drum at one part of the revolution, possible cause?
