i just found this site and thought i would join up and say hi as i noticed your almera`s and our pulsars are pretty much the same
So here is my N14 SSS i brought it about a month and a half ago. after writing off my skyline and selling my GA16 pulsar. (this one wont get turboed)
So far the car has
Hi flow cat and 2.25 inch exhaust
K&N pod with 3 inch pipeing
Gabrial adjustabul shocks and King lows
front strut bar
front and rear sway bars
some un known 15 inch rims
Monza 4 point harness
and some more bits and peices
Work Log
10/9/09
took delivery of the car (not driveable due to a big water leak and powersteering leak)
14/9/09 to 20/10/09
Got new waterhose at the back of the W/P replaced along with a new water pump, also got a new P/S hose made to stop the leak. ( once the hose is put on we discovered the P/S pump is dead)
26th and 27/9/09
preformed a decent service on the car includidng
Top gun leads
NGK Platnum plugs
K&N oil filter
Martini Racing 10w-40 senthetic oil
K&N air filter
Ryco fuel filter
repalced rocker cover gasket and plug seals (as old plugs were covered in oil)
Preformed compression test on car with the results being
1st cyl 185
2nd cyl 185
3rd cyl 180
4th cyl 183
3/10/09
installed a 4 point harness in after we went for a run threw macoden and decided i moved around to much in the seat
also cucked in a Cusco catch can
18/10/09
replaced the stock inlet pipe with 3inch S/Steel pipe
Mounted the oil cooler
Got some Orange indercators
22/10/09
New K&N Oil filter
Martini racing 10w-40
full radiator flush and new Penrite Sin coolant
30/10/09
Got a Leather handbreak grip and leather gear boot from a Jap Spec N14
will put them in on the week end
31/10/09
Leather hand brake grip and gear boot installed
resprayed most of the black interiour plastics matte black again to clean it up a little
replaced door trims with new ones as old ones had holes in them
11/11/09
new martini 10w-40 oil
new K & N oil filter
cleaned Pod filter
http://img21.imageshack.us/img21/1592/24102009393.jpg
So far the car has
front strut bar
Work Log
10/9/09
14/9/09 to 20/10/09
26th and 27/9/09
Top gun leads
NGK Platnum plugs
K&N oil filter
K&N air filter
Ryco fuel filter
1st cyl 185
2nd cyl 185
3rd cyl 180
4th cyl 183
3/10/09
18/10/09
22/10/09
New K&N Oil filter
30/10/09
31/10/09
11/11/09
cleaned Pod filter
