N15 1.6 Parking bulb replacement and Aut. oil change
I'm not quite sure if this is the right forum, but I try anyway. I have a Almera N15 1.6 (1999) sedan Automatic. Parking bulb sitting in headlamp housing is broken and needs to be changed, but I can't get to it for the pipe to the washer tank. I have the following questions for this problem: Is it necessary to take the whole headlamp bowl to switch the bulb or is there another way and how many watts should it be (I have both read that it should be a 5 and a 10 watt bulb).
As for changing the automatic transmission oil, I can find the dipstick and the drain plug, but I can't see where I can pour new oil when the old one is drained. Where is the fill hole?
