Hi guys,
I need a little bit of help. Wreg N15 GX mera (with A/C & PAS)
One of my 3 aux belts is squeeking when the engine is cold. The car has 46k on the clock, with the original Nissan belts. Tried tensioning the two inner ones where I saw the tensioning bolts but no remedy (haven't done it with the locking nuts just the bolts). The grooved inner side of the belts seem to have lots of little cracks on them too, and I am about to do a longer journey so I'd think it's better to change the belts (haven't looked at prescribed service intervals).
Only problem is I have no idea how to remove the aircon belt. I see the tensioners for the PAS and the alternator, but no idea how to loosen the A/C one.
I have the service manual which tells me nicely how to check and tension but no disassembly or swap guide which p*sses me off a bit, because I don't want to pay a garage to do it.
Not much clearance to get to the belts either, so I'm in need of advice.
Thanks in advance!!!
