Hi i have recently purchased an 1998 almera.The key fob was not working,so i changed the batteries.Again no luck.Upon doing more researching on the internet i found the fob reprogramming method.However the indicator lights do not flash on my almera, when i switch on/off ignition six times. From what i found on my searching ,the fob programming mode does not work if max of 4 key are programmed.Is there anyway to reset the NATS/Key system?.
