I have a '99 N15, I have two keys that both unlock and start the car, both have a red oblong on the key body,i'm assuming this indicates they have a transducer in them.
The two fobs are separate, both have half moon buttons, no led, fresh batteries, and neither has micro switches....they use the conductive rubber contacts all of which are clean.
One fob will not unlock the care !
I'm aware of the pairing sequence..the car goes into programming mode,and when the ignition is switched back on again the indicators flash twice....what i don't get is the indicator flash to confirm the programming after the button presses on the fob, its as if the fobs are not transmitting..
Bought another fob, this is exactly the same....no programming conformation,will not unlock the car..!
Update.... I can pair only one remote at a time.... If i pair the other fob it disables the first one...!
Any thoughts..?
Cheers.
Any thoughts..?
Cheers.
