N16 2.2 diesel bad MPG
Getting really bad mpg in my 2.2 almera' dash is reading 25' what could be causing this has anyone an idea? was hoping to get high 30s' types are ok for air all motorway miles' hoping someone on here have the same problom and will be able to help me out' thanks
You should be getting low to mid 40s. Higher still if you mostly do motorway miles.
What year is your car?
Air filter, fuel filter, fresh oil and filter. ECU and fuel pump reset. EGR clean and intake manifold clean (aerosol) can all help improve.
-phone-
Check your earth from battery to chassis and from chassis to engine block. If the earth is badly corroded or only a few strands of copper could be the cause as similar affected my fuel ratio until quite recently.
Also try Forte fuel treatments they have helped with my fuel consumption, and correct tyre pressures if too low could affect mpg. Is the car full of stuff like people, luggage or tools?
To be honest they didnt look that bad at all' no corriosion or frayed copper wires' tuck it all off and gave it the wire brush treatment" put it back on" and tuck it for a spin up the road, straight away the mpg went up and keeped going"
Thanks again man' yr a life saver ;)
Worth fitting an earthing kit have always done so in recent years and improvements are always noticed. Next thing I'm fitting on mine time permitting.
mite go down that route myself""ill see how i get on with it for now' hopefully it stays the way it is'
Just go's to show what a little tidy up can do.
Try the other bits of advice you will also see gains. Especially forte cleaner & egr cleaner
  • Like
Reactions: edk
Just signed up two days ago' Cant believe i didnt no about this site" as aim a big nissan fan and owner for over 10 years +
Wont let me see on my fone for some reason' put diff look at later in the week when aim on a computer'
After seeing the gains from a small job like i done' its well wort looking at everything thats said above'
More mpg more money in my pocket'
I said it before but ill say it again"""
Love this site :) great info and friendly people' thanls again
