N16 2.2 diesel from holland
hi guys
I`m back on the new forum. My daily ride is a Nissan almera N16 ph1 2.2 diesel YD22DTTI.
And already did some mods:
BC- coilovers 75mm lower ride height.
17"x7,5J et40 with 215/45r17 Kumho`s
Peugeot 307 splitter
home made struttbar
K&N replacement filter
and working on a measurement system:
Looks like the splitter doesn't meet the bumper, you could have done the Cupar lip which quite a few people have done on here, but other that looks good dude!! Great height.
Looks good dude, what strutbar have you made? Front or rear?
The screen/data display looks great, are making it to plug into the OBD port or to be hard wired in?
@V-spec, the splitter is a little short on the sides. but it makes a good improvement on high speeds.
@ Liam,
A front struttbar:
CAD design:
mounted
The screen is a hard wired system, because the data in the screen is not measured by the stock ecu.
like Exhaust gas temperature, intake temperature and pressure, ambient conditions and oil pressure, temperature.
Strut bar looks good! Id triangulate from the mounting plates for a bit more rigidity.
Display looks interesting, looking forward to see the finished item.
@ Hally,
Jep i`m using a Arduino mega as a base for the measurement system.
The sensors i`m using, K-type thermcouple for the EGT.
VAG MAP/IAT sensor(combined sensor) for the intake en ambiant conditions.
and some simple 3/8 NPT sensor for the oil system
