Does anyone out there know if an N16 has a module /unit responsible for the normal functioning of the Air conditioning .My car won't switch on its compressor nor its thermal fans .The relays for all these units seem to be working well ,pressure switch in the drier works well,thermister is fine ,main AC
Switch works well.All these gadgets don''t seem to have any continuity with each other or main ECU or Central locking electronic module.I've dismantled most of my dashboard panels hoping to find the
module ,with no luck .
Even if someone has a w/shop manual for this car I would appreciate it if you attached for me the
wiring diagram for Airconditioning.
