Picked up a unit from a breaker and before i swap them over and experiment on the cracked one i was curious if anyone has attempted/succeeded in separating the clear lens from the black plastic housing on a N16 mk2 rear light. From what i can see if it was doable then the red band around the unit will prob need attention after a refit but not 100% positive of this until i try, my main concern is the thickness of the lens as it looks like its gonna just crack on attempt anyway. Also what do you use as a seal, somehow reuse the black sticky gunk or replace with self adhesive foam tape ?
