N16 Passenger Front Window Not Working
My front N/S window has stopped working, from both the driver switch and passenger switch. The disable button is not pressed in and all other windows work.
We've had the door fascia off and popped a multimeter on the power cable, which shows it is getting around 6v when switch is on.
Is this normal or should it be getting the full 12v?
What do you guys think- duff motor, bad earth somewhere or crud in connections somewhere?
