C
CHillY
Hi !
I bought a new almera sedan 1.5 and I would like to know if
anyone's got the same problem. Everything is fine and smooth except when
engine is running about 3000-3200 rpm, then this annoying vibration starts.
It's there with every gear, but because I drive (most of time) economically and thereby use large gears, it is bothering me when I drive about 100-120 km/h with 5th gear. And I drive 85% of the time that gear and speed, so it
really is annoying The vibrating doesn't appear if the car is stopped.
I took the car back 2 times to the dealer, and they searched for the problem
for 2 days. They have never heard about this problem before (so they said),
in 2 different dealerships. Second time I went there to pick my almera I test drove it with a mechanic, and he felt the vibration also, but then I told them that if they got an other Almera with same engine, and it had the same problem, then I would accept it as a characteristic, not a defect that must be fixed. And they got one, which I tested and it had the same problem, and otherwise it was worse than mine too. I didn't feel this problem in the one I tested before I bought it, because I tested it in a different dealership.
Any ideas ?
Any ideas ?
