how would wheels in that size fit on a lowered n16, probably the same sorta drop as ed's maybe a bit more. Would there be any issues? I have no idea how much room there is to play with on the n16s, im aware that theres a fair amount of arch to fill on the n15s.
Its just my next cars very likely to be an n16 and im just thinkin about bits n bobs really
not a chance I got 17x7J +44 offset and with my car lowered and its about 1cm from the arch (Coilovers) 8j with +10 offset will bring it way past the arch.
On a 7J rim you'd get away with ET38 but no less. That's on a moderately lowered car. I.E. I have 7J ET40 on standard diameter wheels with standard profile and the wheels have a few mm clearance to the inside of the arches. If the rears were rolled then you could get away with 7J ET 35, but not on the front unless they were rolled too which would distort the shape slightly.
