i;ve tried searchg the forums but cant find out how to reprogrsmme my fob that had a flat batt.
searched the web and found this
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Then turn ignition switch to OFF position. Leave key in ignition switch.
3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key’s.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key’s for operation.
followed it to the letter, now i have 2 keys that wont work and my radio has reset itself!!!
its ok up till step 4, but as soon as i press the lock button once (i'm assuming on the door???) my lights flash twice and then it all went tits up and now the alarm goes off everytime i open he door.
anyone know how i can reprogramme both my keys? i'l take 1 at a push, better than none!
