how do you know if this is working, i.e. if i put a copied key into the ignition and turned it what would happen???
would it try to start but not fireup like my old punto did or would no dash lights come on???
also how much is it to have a key copied as i only have 1 key and if it breaks or stops working im stuck.
reason i ask is that it could be my immagination that when i went to start the car none of the dash lgihts came on so took keyout and put it back in and it works............. wierd i know could just be my immaignation... i've sa tin the car good 3-4 minutes turning on n off and everything works fine.
also how can i bypass the immob as i have a cat 1 alarm n immob fitted n e how?
