NATS Programming
Alright,
did a search last night on here and found 2-3 ways of re-programming the key fob. Tried them today and non work. I followed all and even took a print of the NATS page someone posted up.
The Master seems ok and I get the LED on dash to stay on but the LED on the fob continues to flash instead of turning to a constant light. Held red and blue for 10 secs and then longer and shorter to try it but no change.
I then switch the ignition off and it beeps 5 times at me and its armed again but the fob doesnt work.
I replaced the battery first so thats ok.
Any ideas??
Also, the Master cant be used as a fob can it?
Im stuck. If it doesnt work, Ill have to sort out an uprated alarm system.
Cheers
I got same problem i think
when i go to lock the fob light just stays on or doesn't come on at all. have to keep pressing blue and red again and again and somehow randomly it locks... more of a problem when unlocking!
Was thinking of just dumping this crappy Nats alarm and getting a cheap Viper Alarm system put in
try doing the both button thing for as long as it takes for the led to stop flashing, sometimes it takes a while. Make sure you are stood next to or sat in your car aswell.
If the dash LED doesn't flash or if the engine light blinks, there is a problem with the NATS.
Oh, and if your master doesn't work as a fob, I don't think there is any chance of sorting it out. Whatever code if gives to your other remote, it will never work.
The master can be used as a fob, although it's not recommended.
The Master doesnt work as a fob at all but it does 'connect' to the led and seems the alarm for setup.
Its the NATS fob that doesnt seem interested at all.
Today I opened the car with the key as always to start it up for a bit and it beeped at me. Still started and LED went off. Is this anything??
