hi,
i have a 2002 1500 almera that has been giving me problems (no power,stuttering and more). i looked on here and got the answer that it was the mass air flow sensor. i got a new one off the net and all seemed well for a few days but the problem came back. i bought a code reader and it said there was a problem with the supply air temp sensor circuit. i have found the problem. inside the mass air flow sensor there is a resistor/component soldered between the middle pin and the right hand pin. mine has broken in two. can anyone please tell me the value (ohms or whatever) of that item so i can solder a new one in...otherwise its buying the whole thing again...
thank you
thank you
