New member with Almera Activ 1.4 (1997) need distributor
Hi there all. I am a new member with an Almera 1.4 Activ (1997) and I need a replacement distributor.
I have had my car for the last 10 years and it has been brilliantly reliable and had not let me down once apart from requiring the sills welding a couple of times. That was until recently! switched the ignition off one day and two weeks later tried to start it with no success. Proved there was no spark at the plugs. Had it towed to a garage (£40.00). Mechanic couldn't get it to go. He called in an auto electrician who said it was the distributor at fault (£80.00) and then I had it towed back home (another £40.00).
Since last week I have been trying to get a distributor for this car from loads of different sources. None has the 6 pin 2 electrical terminal version that is on my car. Is there a member out there that can point me in the right direction please?
I need this info too
My distributor is like this:
22100-82j00-delco-distribuidor-de-encendido-nissan-almera-primera-sunny-mazda-626.jpg
But i only found like this:
Can you help me ?
That one with 5 pins will work on my car ?
Thanks !
---> Nissan Almera GX N15 from 1995 <---
