so here are some new pics of my car and I have done "little upgrade" of my engine... pics on 3 pages : http://nismo.cz/new/album_personal.php?sid=f2dea6c24d8b0586c11955176ed3c0e1
my specification of engine mods:
- forged pistons WOESSNER - custom pistons made according to my order , pistons with raised comp. ratio on 11:1
- forged H rods EAGLE with ARP 2000 bolts
- head work: reground head, ported and polished, valves - polished and reground
- adjusted block - reground, drilled only about 0,5 mm from 86 to 86,5 mm, made new custom piston coolers (nozzles???)
- regound cylinders
- all new gaskets, head bolts etc.
- new timing components including timing chain ( timing chain kit)
- lightened flywheel, metal-ceramic racing clutch with graph up to 664 NM,
- cams fromJIM WOLF TECHNOLOGY - JWS3R
- new custom exhaust: header from SS autochrome, Downpipe - 2 pipes from header (downpipe) with diameter 57 mm, joined to the pipe with diameter of 60 mm, metal sport cat with diameter 60 mm - highflow, 2 silencers - one is highflow and back box on the end of exhaust with diameter 104 mm
- polished intake manifold
- oil cooler - just not fitted
- adjusted injectors - completely profesionally cleaned, raised flow up to 30% + raised pressure in fuel pump
- red painted valve cover + intake manifold
- ECU upgrade, RPM limiter advanced on 8.500
Compresion ration = 11.5 - 12:1
I hope that soon be fitted:
- Fidanza flywheel
- unorthodox racing pulleys
brakes specification:
Brakes:
- D2RACING 8 pistons front brake kit
- little upgrade of rear brakes - better pad to be fitted
Suspension:
- I will order this month D2Racingsport adjustable kit with adjustable camber plates...
- ENERGY suspension bushings are fitted
Sorry for my English, I´m still learning....
- regound cylinders
- Fidanza flywheel
Brakes:
Suspension:
