New Tino owner
Hello, recently bought a 05 1.8 SE tino. Very happy with the car but have a couple of queries, I'm going to do my own servicing and wondered if anyone could tell me if I should use 5w30 semi or fully synthetic oil. I intend to change it every 6000 miles as I think thats long enough for oil to last. Also do you recommend genuine Nissan oil filters or are after market types ok? Finally,I have a very slight high frequency rattle from the gearlever in 3rd and 5th,its so slight that it stops with the lightest of finger pressure on the lever. I don't think its anything too sinister as I understand the transmissions are very robust, but has anyone had maybe a worn bush or other linkage wear. Thanks in advance.
Hello there,
6,000 miles is a good interval for an oil change, and semi-synthetic is recomended by nissan i think. The oil filter is up to you really, as the after market types are fine to use.
As for the gear lever - it seems to be a trait of the N16. Some days it will do it, and some it won't. Does your tend to rattle during heavy acceleraton?
Hope this helps,
Matt
Hi mate, not many of you tino owners on here! use good oil , not own brand stuff do a search for opie oils think you can buy filters and oil packages cheapish thru them!
