Nissan Almera 1.4 Action.
Wife loves her Almera and is hoping I can keep it on the road!
Sump pan is badly corroded and I will need to replace as it is now leaking oil.Is this a straightdforward job or will other parts need removing to gain access to enable removal.
Thanks.
from memory i think its a case of remove the small support brace that goes from the gearbox to just above the sump, then a load of 10mm bolts, i dont think you have to remove the cross member/engine support
