V
Veero
Fatal mistake agreeing to look at a neighbours car...
Anyway, 1.4 12 valve Sunny, G reg so all mechanical timing and vacuum advance etc. It's running really lumpily and will die if you don't keep giving it throttle. On idle (with throttle to keep it from stalling), it sounds like it's got an intermittent misfire.
The battery warning light is faintly on all the time and then comes on brightly always just as it stalls which led me to believe it was the alternator but its putting out 16v when you rev the engine with full beam and fans/heater etc on so it's definately charging. Battery voltage is steady and healthy. I've know of someone running a 309 on battery alone for a few miles once when the alt belt snapped, so it should run for at least a short time if the alternator was kapput
The old guy said he put half a tank of super unleaded in it, now it being an old car designed and timed for normal unleaded would putting SUL make it misfire splutter and cut out?
Any ideas greatly appreciated.
Veero
Veero
