Odometer help
Guys,
I need some help.
My mileage counter has starting intermitently working.
Can anyone direct me to the connections so i can check these before going crazy and ripping the full dash out, car is phase 1 gti.
Any help would be much appreciated.
hmmmm could it not be the dash not working could it be a problem at the other end where it sends the signal to the dash ?
try to find out whats wrong and then if its the dash buy a new dash and swap it over and write down the mileage. make sure you note down the mileages and make a video and sign and date it.
With it being intermittent i'm hoping that the sender connector may have come loose?? Just need to know where it is so i can rule this out really.
phase 1's have mechanical odometers so it wont be a 'sender', it will be a cable through the bulkhead. i'll dig it out in the FSM
i stand corrected. it is though the plugs. see the diagram below. I would have though it is linked to the speedo, so wires 12 and 10 will be the ones you need to look at.
That looks like what i'm after hally. cheers
Does anyone know where the other end of these cables go to so i can check that connection too?
