Poor starter
My cars developed a bit of an intimitant problem.
Every so often it has trouble starting. It tries to turn over but doesn't. All the dash lights flicker on and off and there's a timely beep beep beep with it.
I even have a vid if u need to see it.
It's never failed to start but......
What could be the problem?
Its a common fault apparently it gradually gets covered with clutch dust? Either remove it and give it a good clean or try getting a replacement.
post the video mate but sounds to me a weak battery or loose battery connection. does the beep beep beep come from the alarm ??? as this is what happens to my car when i fit a a weak battery onto it. try checking the battery fluid first top it up if needed and try getting a battery recharger and stick it on slow charge so not to damage the battery and see if that works. keep us posted
