power cable for amp
  • Thread starter Thread starter black_sri
B
black_sri
hey guys i want to fit an amp in my mera. but im not sure where to run the power cable, and if i need to drill a hole from the engine bay in to the car or if there is already a suitable hole. could anyone advise on how they did it, any help will be much appreciated :)
if you go into the passenger foot well and in the middle, just above where the carpet stops, theres a rubber plug, about 2" in diameter, pul lthat out and theres a hole to the engine bay. then u can run cable through and under carpet etc
As said about.....however, I took a screwdriver and made a hole in the rubber plug and you have the seal and a route for the cable!
But If You''v Got Air Con Theres A Pipe In It. I Havent Looked In My Engine Bay For Awhile So I Cant Remember If There Are Anymore
thanks for your replys, its probably just me being thick but i can't see the rubber plug. there is something that looks like you described but doesn't seem like it pulls out, and i think is attached to something, i put an arrow pointing to it in the photo attatched. is this it? by the way i do have aircon.
Here mate, this is mine (tho it is an N16) hope it helps. Soz bout the size of the pics.
black-sri---- it that a pic form inside the car??? it would be easier finding the hole from inside the engine bay
if it is ignor me photo is abit blurred
yeah it is from the inside of the car, i did have a quick look in the engine bay. couldnt see anything though.
Hole is higher up behind the glove box from the inside of the car just above where the sound deading mat finished
ok cheers mate. do you need to remove the glove box to get at it?
