lucinovzr Feb 17, 2015 #1 Hi guys just wondering if the engine and box from a 98 gt is the same as a phase 2 gti? Is the gt box any better and is it compatible with gti shafts Are the mounts the same or can you bolt the almera ones to the engine. And finally if a gti ecu will work with the primera engine/loom
Dyldo Feb 18, 2015 #2 Box is exactly the same in every way. Although some GTs had slightly shorter gears. Gti ecu should work but a few pins need swapping about I imagine Sent from my SM-G900F using Tapatalk
S Sam Moderator Staff member Feb 18, 2015 #3 GT ECU will work as long as you have the nats bits. Just use the gti loom/ecu on the engine.
chunky Feb 18, 2015 #4 Sam said: GT ECU will work as long as you have the nats bits. Just use the gti loom/ecu on the engine. Click to expand... Seem to recall some sensors being different? Maybe that's only if you used a GTI ecu. ....Phone.....
charley Feb 18, 2015 #5 Exactly what i needed to hear i have gt engine and box but no gti loom. Ive heard the same chunky, about having to use the gti sensor's and also not using the gti loom going be a night for me being colour blind basically i will need to use the nat's box, from the gt also? i'm excited to say the least!
chunky Feb 18, 2015 #6 If you use the GT ecu you will need the accompanying NATS bits for that ECU ....Phone.....
lucinovzr Feb 19, 2015 #7 Does it have to be specific for that ecu or can I use a different nats box from a primera gt
