N
nutcake
On my 1.4Si P reg w/97kmiles i'm having an issue starting from cold, I have to feed it a little gas to get it going.
Any ideas?
Any ideas?
dub_almera said:hmm.. maybe its the start motor going?? next time it happens in the cold, try a push start, if it starts first time on a push, then it could be the starter motor... also, when was the last time you changed the plugs and did a service??
gloves86 said:yeah could be either of those...when you say takes a little extra throttle, do you mean it turns over fine but won't spark? or does it sound like it's labouring when you turn it over (like a flat battery). If you're losing electrical power...check your boot light goes out when you shut the boot! lol
