HI everyone, got a problem with my N15 GA16DE
my car rattles and smokes under load and acceleration usually up hills too.
its fine when it idles and when maintaining speed on level ground.
it did it once a month ago but last 2 days it has gotten frequent and im getting worried.
when it does it, it rattles and hesitates to accelerate then large puff of whiteish blue smoke and clears and then i have full power.
compression is fine
oil was low and i have topped up
coolant is fine and not milky
when it rattles it sounds like a diesel engine
the smoke is not constant
I dont believe it is a blown head gasket or worn rings because it still has all its power when this problem isnt happening, but correct me if im wrong
ive heard these can be the problems
VCT is playing up
PCV valve
valve stem seals
i do need help ASAP but any help is better than none
compression is fine
VCT is playing up
PCV valve
valve stem seals
