If you have money buring a hole in your pocket, order yourself some cams
Last place to spent money usually
A rolling road tune can be very beneficial, a good dyno tune checks compression, spark plugs, leads, emissions, MAF clean if needed and ignition timing. Plus advising you on any issues the motor might be having. Something that’s gradually getting worst over time might not be so easy to detect.
It’ll all help to bring your motor back to stock power and with good quality fuel, clean MAF and ignition advance circa 4 – 6whp can be had. If your planning any engine mods in the future a base figure is handy too.
id recommend a remap, i did a remap on on my oriogonal gti engine, got 165bhp, with std cams, manifold/decat/cat back system and induction kit,
but i did have a ported and polished and skimmed head, on a fresh built engine,
cold air feed as heat soak sucks?
cold air feed wont effect heat soak at all, yeah it make the heatsoaked air that bit cooler, but its not getting to the root of the problem. and even then, a cold air feed wont work until hi speed.
