ive had this problem with my bumper... what primer have u used?
i used a HOLTS one (i think) but its reacted with the top of the bumper?
Nice input joe.
Panel wipe clears MOST things.
However there CAN be a few factors simply out of your control. From a painters point of vue.. Anything has a possibility of reacting.. Esp when things have been painted Since the factory.
Aerosols also are a nightmare at times.
Halfords paint should be AVOIDED AT ALL COSTS..
Do a quick Yellow pages search for your nearest paint suppliers.. They are full of advice and the 'paint match' systems they use are 10x times better. Not just a better match.
Better coverage,
Better atomisation ( leading to a better finish )
Better consistancy ( reducing chance of runs )
Massivly less re-active than halfods or motorworld shit.
Alternativly, nip in to a place like ours and blag a quick blow over of your part, for the price of a few beers.
well aware halfords paint is crap, but i have never had a problem with there primer, i know it may be small beer but i have sprayed 3 bumpers, a plate surround, sideskirts, a grille and 4 wheels and never had a problem like this.
i do go to a proper paint shop for my base colour.
so i guess i gotta sand this right back to the original colour it was then?
its the splitter i got from you kristian, i think you will agree it hasnt been painted since the factory?
also craig, spraying in the garage with a propane heater
you could also be trying to dry it top quickly!
if your putting the heat directly onto the panel!
this will cause a shrinking affect aswell!
even pro painters of 30 years still get reactions at times! there is too many things that can cause something to go wrong!
you can only minimise and reduce the chances you can never stop a reaction happening at all!
sound advice from K there - as said only thing i would personally add is if you were directing the heat straight at the panel!
Bodykits are for gays anyway
