rear bumper
  • Thread starter Thread starter spen
S
spen
can some tell me how to remove the rear bumper pls. im going to atemp doing myt rear arches and remove all the dam rust .
just look for bolts and take them out, then take off the clips you can see along the top when you open the boot
make sure you get all the bolts and it'll just slide off
sri_alan said:
Search with the phrase "rear bumper removal" you'll get your answer
:rolleyes:
Like Kieron said, just take every screw/clip/bolt you see, there held on pretty well.
just don't lose any, or it'll never be the same.
Good idea to remove the bumper whilst doing the arches! Another place where rust builds up is on the rear slam panel and tow hook area, try and get that too!
look up from underneath is my advise :)
lol
cpl under the rear arches - clips under tailgate close section and about 6-8 on the underside holding it to the support frame
and it slides off!!
1 10mm at the bummper tip in the wheel arch, 4/5 clips along top edge where the tailgate shuts and about 4/6 clips/10mm boks under neath
GTi kurt said:
:rolleyes:
for your information kurt, i did actually list the process of removing the bumper but then thought i would point out that in the same forum was the exact same question from about 2 months ago, and it would be easier for him to re-read that than wait for another 10 replies on in this thread.
telling the guy to remove every bolt he see's doesnt really help him if he doesnt know where to look
