hi, i have a phase 1 GTi, would a phase 2 rear light cluster fit staight into a phase 1?? would i need to do any re-wireing?? or is it a straight swap??..
thay can be tricky to remove once you remove the nuts from the inside of the car as they are sealed in place with black sealant stuff. iv found a screwdriver can be usefull fo wedge them out a bit so you can get a right hold of the light and pull them free.
