Rear washer
Hi guys anyone point me in the right direction to removing the rear washer nozzle as its blocked and hiding under the spoiler -.-
Thanks
Alex
The tubing goes down the drivers side of the car, if you remove the trim panel above the speaker there is a connection there you could probably get an air line on.
I've investigated and it's literally the last bit of tubing that disappears up the central hole in the boot, so literally just the nozzle that's blocked now :( reckon I could get it from there? Been trying everything.
it's originally double sided sticky foam and bolted on, some heat from a hairdryer/heatgun and a length of fishing line to 'saw' through the foam should see it off with minimal effort :)
I saw someone unblock some washer jets over the weekend with a bike pump on the end of the tube, worked a treat.
  • Like
Reactions: edk
