You can try and knock the old ones out but the threads inevitably get fucked in the process. Studs are sold seperately though, about £3 each. Did the bearings go in both rear wheels?
heat the old hub and when its glowing red hot round the stud just give them a tap should fall out you might also wanna try winding the nut onto it first so you have a larger target to hit and wont hit the threads
