Hi again guys. I kind of kerbed this as I thought the service would sort the problem out. It seemed to for a little while but unfortunately it’s back again.
I’m not very technical minded so don’t feel confident trying to tackle the problem on a trial and error basis. Would dearly love some help from those in the know….please?
There doesn’t seem to be a set pattern as to when this will happen. It initially happened when I was on the motorway and noticed it when I put the clutch pedal down to change gears. The revs wouldn’t come down when the clutch was depressed or when in neutral. However it does when in gear and the revs match the engine speed etc all as normal.
More recently it happened when I filled up from Tesco’s (doubt this is the problem, right?), again revs move up and down with engine speed etc but when the clutch in depressed and when the car is in neutral it just shoots up between 2-4000rpm. So assuming there is some problem with the cars idling? The rather annoying this is it doesn’t happen all the time and I can’t work out when it will or wont happen. I’d tried pushing the accelerator pedal up with my foot when it happens but this only lowers the revs ever so slightly. I do suspect a sticky throttle cable but what can I do to free this? WD40?
Has anyone else had this happened before?
Rowdy-GTi do you think it still could be something to do with carbon deposit in the throttle body?
