tomorrow i will be removing the rocker/cam cover to polish it up. can anyone tell me if the gasket is made of rubber or paper, if it is rubber is it re-usable or a new regardless?
thanx for any info.
If you are reffering to a Gti then its rubber mate, if its in good condition and no tears or splits in the rubber then its fine to replace it again, but be careful not to nick it on replacing it back on the cam casing. A tip is to fit it inside the seal well underneath the rocker cover first mate
sparky, sorry, yes it is the gti, thanx for the info m8, just what i needed to know.
on another note, do you know what the torque setting is for the bolts upon re-fitting the cover?
