Hello!
I've recently purchased a 2004 1.8 SXE. It comes with the Sat Nav system.
However there seems to be a problem with it.
After a couple of minutes the display will have a green backed secure message on it, and only the info displays and Climate control will work.
Also, before it goes into Secure mode the buttons on teh facia work, but the radio takes no notice of anything thats pressed. For example I can start the car up, turn the volume control, and the current volume level appears on the screen, but doesn't change. Its the same if i try and change the radio station, the key press is shown on the display by changing the button to an orange colour, but the radio system just appears to ignore the input. Same if i use the steering wheel controls.
The Src button will change to the CD input, but it doesn't actually notice there is a CD inserted.
The sat nav works OK, and the button presses work fine for that (until it goes into secure mode)
Is it likely to be faulty wiring? or am I going to need a trip to the main stealers to plug it in and make sure its all coded to the car?
