I realise that i've just started another thread in the same section, but i've got loads of ideas going through my head about how to install my new speakers up front. I'm not too fussed about the rears at this stage, so they'll be fitted in the standard locations.
I'm going to modify and standard A-Pillars to accept the bigger tweeters and this is fairly straight forward... BUT, it's the mids and the crossovers i'm thinking about and without my car in-front of me it's hard to actually plan this properly...
If the door cards are the same as the P11 Primera, i'll be able to remove the lower section which creates the door pocket. I can then make a build onto the outside of the pocket to accept the crossover and flush it in. Not too sure how to do the mids yet, because i want them to be seem - not hidden away behind the OEM grills, but at the same time still be able to bolt them to the door frame, not the door cards.
Have a look at this install over on NPOC, which should give you a better understanding of what i'm on about - http://www.npoc.co.uk/forum/forum_posts.asp?TID=608
Just need some ideas/inspiration please! If anyone can point me to some photos of what others have done that'd be spot on.
Thanks.
Thanks.
