speedometer Gauges problem
hi every1.
am new to Almera. well, my car is having a problem recently. the speedometer, gauges and mrp clock stops working every morning and then after 1h it starts working.... any suggestions what should be causing the problem?
:confused:
Welcome mate,
To me it sounds like some bad cables or even a cold joint on the inner PCB...try reconnecting the gauge cluster, mby get a electric contact spray and spray the gauge cable sockets... if it won't hepl get a new cluster.
Daft question but have you checked your big ass fuses under the bonnet near the battery?
When I blew the fuse doing my manifold, the dash would come back after about 5/10 minutes but had nothing when first turned.
Thanks buddies.. ill check the fuses. but can u explain what is a gauge cluster???
do i need to open the dashboard panel to check for the connections?
