Someone correct me if im wrong but iirc Rowdy has fitted an SR16ve N1 gearbox to his SR20, with no mention of switching the clutch, so an SR20DE clutch should be fine.
I'm a mechanic I fitted it myself the clutch kit cost me 164 all in release bearing pressure plate included. I suppose most mechanics would charge abou €200 to do it. I had a nismo paddle clutch in but it was killing my leg so I changed. To be honest I see no difference between the two the kit I put in doesn't slip at all.
