Push the cover down on top of the wheel to reveal the airbag retaining clip, pull clips outwards, airbag will come away. Unplug the bag/spool. Undo nut in the centre, i think its a 19mm but its been a while since i last removed one. Top tip, dont take the nut all the way off, leave a couple of turns on when trying to pull the wheel towards you so you dont hit yourself in the face!
possibly a silly question but how does the yellow plug disconnect from the airbag? can't see how it comes away, thanks.Push the cover down on top of the wheel to reveal the airbag retaining clip, pull clips outwards, airbag will come away. Unplug the bag/spool. Undo nut in the centre, i think its a 19mm but its been a while since i last removed one. Top tip, dont take the nut all the way off, leave a couple of turns on when trying to pull the wheel towards you so you dont hit yourself in the face!
