steering wheel vibration
can any one help when i go between 60 and 70 mph my nissan almera n15 starts to shake ive had tracking done few months ago and had tyres on and balanced can anyone tell me why it is doing this
Some things to check are,
Bad/dry inner cv joint/s
Out of true driveshaft/hub nut tight both sides
All wheel nuts tight as should be
Bent rim/flat spot etc on the tyres
Bad engine mount
Tire pressures
Swap your wheels around front to back,see if that helps.I would say best bet though it's your wheels needing balancing again.
I had a wobble few weeks back took it back to the guys that done tracking/balancing done it again and still same, took it to a different guy who done it n its been fine since! :/ maybe try a different garage if you can't find anythin else obvious??
