you will need a hi-to-low converter that you use to tap off the rear speakers
the power cable is pretty straight forward.
the remote wire you need to use a tester and get a ignition lead from the head unit or you can use the ciggy lighter like I have done
ground (loads of mounting points under the carpet of the N16
rear speakers rip out the trim and connect it to the hi-to-low converter or you can run it from the head unit but getting it from the rear means you do not need to use a 5m RCA lead
PM me for more info if you want and I can tell you how to remove it. or if you want I can meet up with you and work on the car.
