Tail strip brake light problem
Hi there, the strip light in the middle of the windscreen stopped working yesterday but all other tail lights, brake lights etc work. There does not seem to be a fuse specific to this particular light. I removed the light itself and tested with a power source and the light itself works fine. All cables seem rust and moisture free. Anything I could be missing?. Its the N16 2002 almera petrol 1.5 sport. Any suggestions are really appreciated :)
Strange, looking at the wiring its all off the same circuit and fuse as the lower level brake lights.
So the connectors/earths are all fine?
Hey, thanks for taking the time to reply, yeah the connectors are fine but the earth, hmmmmm, thats something I have to check, thanks a lot for your suggestion, I will update my findings :)
After stripping back i found a severed wire, red with a gree stripe coloured wire. So a bit of rewiring and all is working. Thanks for your help, without your earth wire suggestion I would not have uncovered the problem
